I recently replaced the water pump in my car. I had no issues other than no A/C. Within a few months i had heat and everything was working fine. So I started troubleshooting. I replaced the Duo valve/Heater control valve, thermostat, temperature sensor on the block, blower motor... Just because, auxiliary water pump, checked fuses, replaced the clutch fan, cleared error codes, flushed entire system and am not hearing any problems with the flap motor. I am at a loss. I am not sure if there is a relay that could be bad or if it could be a SAM issue. Any help would be highly appreciated. Thank you. Craig O.
Nov 10, 2019 at 7:47 PM
