My radiator cooling fan is not working why?
2005 BUICK CENTURY
150,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
FORDMAN969
Just recently replaced the head gaskets (overheating blew gasket), temperature sensor, both fan motors, heater core and the radiator. Driver side fan kicks on just after coolant starts boiling and passenger side weakly tries to start but can't go as fast. I've checked all fuses and relays related to the fans and they're all good, max A/C should kick on passenger side but doesn't. I need advice and things to check.
May 12, 2020 at 1:55 PM
This is most likely one of two issues based on everything you replaced. Either you have an issue with the PCM not commanding them on the proper speed, or you have resistance in the wiring.
Try jumping 12 volts directly to each fan motor to ensure they are capable of spinning at high speed.
If they can, then you are not getting 12 volts to them when you should. Again, either the control module is not sending 12 volts or the wiring has high resistance not allowing the motors to get 12 volts.
You can confirm this by measuring the voltage you have at each fan when the A/C is on and the coolant temp get higher. Both fans should be on high at this point.
At that point, you want to measure resistance from the relay to the motor. Then to the PCM.
Let me know what questions you have. Thanks
May 12, 2020 at 2:41 PM
AKRACKER419
My cooling fan does not come on at all regardless if my A/C is on or not. i would think that it would kick on after my temperature gauge reached half way or better but still nothing? why will it not come on?
May 26, 2021 at 12:18 PM (Merged)
STEVE W.
  • 15,113 POSTS
GM fans in that vehicle turn on at 223 degrees and turn on for the AC if the air temperature is over 122 degrees. The only item you may want to check is the actual AC pressures and the pressure switch. It should activate at pressures over 190 psi. and turn on the fan. If you have access to a shop or an OEM level scan tool you can test the fans operation very easily and without touching anything under the hood until you have determined if there is a problem.
PATCAL096
The cooling fans are not coming on unless I turn on the A/C. I have a obd2 adapter, using Torque Pro I checked the coolant temperatures to see if the fan came on at the right temperature. It got up to 221 F without the fans coming on. I have not coolant loss and all my hoses are uniformly warm. No cold spot in the radiator that I could find. I also pulled and reseated the three fan relays with no change. Not sure how to check the relays without buying new ones. Any thoughts? Thanks.
Pat Callaghan
CARADIODOC
  • 34,306 POSTS
221 degrees is not hot enough for most GM vehicles. They need to get much hotter than other brands before the radiator fan will turn on. I always remember 226 degrees, but some experts say it can be even higher.
On most cars you can force the engine computer to turn on the radiator fan by unplugging the two-wire coolant temperature sensor. Turning the fan on is the default in case the engine is getting too hot. The computer will not know it, so it runs the fan to be safe. Doing that will set a diagnostic fault code. There is nothing to worry about, but it is a good idea to erase that code so it will not confuse someone in the near future. The only part of the circuit you are not testing this way is the sensor itself, but failures of temperature sensors is extremely uncommon because there is just one part inside them. Corroded connector terminals that add resistance to the circuit is more common than a failed sensor. That corrosion typically will not cause an incorrect temperature reading of just a few degrees. It is more likely you would see something around 100 to 150 degrees, and it is even more likely you would have an erratic idle speed tracking the erratic sensor readings.
PATCAL096
Thanks for the reply. Wow! I thought 221 was hot. I was going to pull and test the relays tomorrow but I will retest with a little higher temperature. The thing is, the care was not this way when I got it last August. The temperature gauge was always less than half. Then this spring this started. Maybe I am paranoid but I want to know those fans are coming on without the A/C. I will update tomorrow.
JERRY98
  • 6 POSTS
I let my car run today at idle for an extended time and noticed my radiator fans never did come on, the temp gauge stayed around the notch below the halfway mark, never did go much beyond that mark. The hoses was hot but the fans never did come on. Is this normal? Can a car keep itself cooled enough on its own without the fans running? No signs that the car is overheating. I recently had a coolant flush (routine) and last year a new thermostat installed. The fans work fine when the AC is turned on.
SATURNTECH9
  • 30,869 POSTS
The fans dont come till 222-228 depending on what the computer is programed to turn them on at.So if the temp didnt hit the correct temp the fan wont come on.If it didnt boil over thats a good sign.If you want to get a infared temp we can check and see how hot its getting etc.
JERRY98
  • 6 POSTS
The fans finally came on after a 20 mile trip then letting it idle. The temperature gauge went past the half way mark (almost to the next notch) before they came on and then cooled down to the notch below the half way mark. But thanks for your advice, now you have me interested in one of those infared guns:)
SATURNTECH9
  • 30,869 POSTS
You can get a pretty nice infared gun on amazon pretty cheap.I recommend a ray tech one i bought when they first came out.I have since like 1994 or 1995 and still works great.
GORDON321
i just replaced the thermostat, radiator cap, coolant sensor, and checked all relays on my car. the cooling fans still are not coming on when the car reaches normal temperature. then it starts to go past the normal temperature and the fans will not come on but when i unplug the coolant sensor or turn the air conditioner on both fans come on. is there another sensor, switch or anything else that controls the fans? if so what and where is it located? please respond ASAP. By the way nothing is stopped up.
BLUELIGHTNIN6
  • 16,542 POSTS
Three cooling fan relays and an engine coolant temperature sensor are easiest and cheapest on the circuit that could cause this issue. if they have been checked/replaced already than all that is left is the power-train control module (PCM) .
DOUG S.
It seems that my cooling fans are not coming on properly. They do work, I have replaced three relays and a fuse on the car. The temperature gauge will go up to the 3/4 mark, then the fans come on but only cool it down the the 1/2 mark. If I am driving on the highway, the temperature gauge stays between 1/4 and 1/2 mark. Also, I did replace the fans. Is this normal for this car? I have only had the car for three months?
JDL
  • 16,098 POSTS
I would try replacing the engine coolant temperature sensor which controls the fans via the PCM. Here is the fan wiring diagrams so you can see how the system works and the location of the sensor with a guide to show you the steps to replace it:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Cheers
LVZNLO
  • 0 POST
I got the sensor for $28.00 it fixed the problem!
May 26, 2021 at 12:19 PM (Merged)
JOSEPH RANDALL
Dude... I just happened on your post!
Yes! i have the exact crazy symptom! Car I could swear when first got it always showed lower than halfway mark? Under load up hills, sitting, my scan tool indicates they come on at 215F, and I pressure tested, replaced thermostat (only cause of dumping sealer in it), I've bled system, freaked thinking it was the TSB with head gasket, but it holds pressure, comes back down, and only goes to 3/4 past. But to me.. this isn't normal and I never saw this working on any model?
Suggestion.. I'm installing a switch and using the signal area at relay. basically I'm making my own ground I can turn on in traffic and if I need to? It makes no sense? Don't have combustion in system, don't have air in it, fans turn on with A/C request, it simply reads way higher than i consider normal?
The fans come on at 225-230 in that car, does it overheat boil over? We should do a chemical check for the head gasket this guide can help us:
DEANLANDIS
Electric cooling fans will not turn on when engine gets too hot. I checked the fuses and relays. They are good. I replaced the CTS and it did not fix the problem. I did discover that if I disconnect the electrical connector to the CTS, the electric fans will turn on and stay on. I have left the connectors disconnected temporarily so that the engine does not over heat. In doing this, I've noticed a drop in gas mileage. Please help. Oh, the radiator fluid level is good.
HMAC300
  • 48,601 POSTS
the reason your gas mileage dropped is you disconnect the cts and it doesn't control the fans. plug it back in. There are 3 relays not 2 and 2 large fuses. they all must be checked. I'm including a diagram. If it's not a relay, then you'll have to have a pro check it for a bad connection or shorted wire coming from or to the pcm.... Heres a guide on checking relays and one on testing wiring, they will help you figure this out https://www.2carpros.com/articles/how-to-check-an-electrical-relay-and-wiring-control-circuit https://www.2carpros.com/articles/how-to-check-wiring
https://www.2carpros.com/forum/automotive_pictures/406719_relay_diag_1.jpg
DOUGLASEBOGGS
the relay was bad thank you.
HYDRO605
Radiator fans do not work. I have replaced all 3 relays, as well as the coolant temperature sensor. The fans do come on when connected to direct power as well as coming on when the a/c is is turned on, but they only operate at a low speed with the a/c. Any ideas?
You have two main power fuses, 30 and 40 amp in the main fuse panel, check these first, then check for power/ground at the relay, if all checks out you will need to check the electrical wires step by step with a wiring diagram below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
DALICH
  • 7 POSTS
I have recently replaced the ECM thinking it is bad b/c the cooling fan and AC fan are not coming on. Even when turning on the AC, no fans or compressor. The new ECM made no difference.
The relays and fans are fine. I believe that the cooling fan relay "should" have a hot link to the relay and the ECM then grouns the other side causing the relay to close. I did not have the "hot" side on the relay and when I cut and jumped this wire to Hot, the cooling fan will turn on and off with engine temp.
Is there a fusible link in the wiring harness that supplies the hot side to the cooling fan relay? If so, where is it and what are the wire colors? I was told to look for a real along side the steering column but cannot find anything inside the passenger compartment.
In summary, ac compressor, fan and cooling fan not working. Fuses in fuse block are fine. No hot wire to cooling fan relay. Is there a fuse somewhere inline?
JDL
  • 16,098 POSTS
Here is the fan wiring diagrams and the relay location and a guide to help you test the relay.
Cheers
DALICH
  • 7 POSTS
Okay, judging by the wiring diagram it is looking like the 10A in-line fuse (behind the right side of dash near upper left rear of glovebox). The fuse center is located in the glovebox. I removed the glovebox where I can see all the way back to the firewall. I cannot find this inline fuse. There are a bunch of pink wires, but I cannot find this inline fuse. it is a 1995 Buick Century 4 cylinder 2.2L
I have a very good view, I just do not see this inline fuse.
Never mind....... Just found it. 3 fused links were taped together out of sight. Felt like a plug but when unwrapped I found the fuses. 10A, pink wires, blown. All fixed! thanks I love this site.
Thanks,
Dan
JDL
  • 16,098 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
CHASENDRAKE
I am trying to figure out why the cooling fans do not work and the car overheats, there are 2 fans on the radiator ands niether work, i replaced one fan motor and the thermostat seams to be working but the fans won't come on when engine gets warm, can you help with this problem? thx
LEGITIMATE007
  • 5,121 POSTS
is there an engine light on?, does the fan come on when you turn the a/c on or turn the defroster on?
CHASENDRAKE
There is no light on and when i turn the air conditioner on , no fan works, the guy at the auto parts store said it may be the relay or the fuse under the hood but i do not know where these are located if you could help with the location of these items and if you think this is the problem please let me know thx
DOCHAGERTY
  • 9,603 POSTS
The relays are behind the right headlight and the fuse box is in the glove box.
