One radiator for coolant and air compressor?
2016 HYUNDAI ACCENT
69,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JUNIOR1964
  • 36 POSTS
Hi, i would like to know how to know after i turn on the air compressor is working.
Jun 5, 2024 at 6:50 PM
The best way to tell is to connect a set of A/C gauges because this kind of compressor does not have a clutch, instead it has an internal valve that is controlled by the AC control module. To see if the compressor is getting a signal you will need to remove the wiring from the compressor and connect a test light or voltmeter.
Here is a guide that can help and the wiring diagram for the compressor:
Jun 6, 2024 at 7:56 AM
