On-Board monitoring readings
1996 JEEP CHEROKEE
116,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DAMRPH
I am getting a Test $19 Data fail and Test$1a Data fail reading on my Creader 3001. What does it mean?
Thanks
Mar 21, 2022 at 6:03 PM
Can you get a couple pictures of this and let us know what you are finding these under?
When you say you are in the on-board monitoring readings, I assume you are looking at the PCM data as these would be the OBD codes. However, this sounds more like an emission monitor test failure code.
Do you have a check engine light on?
Let's start with seeing the screenshot of where you are getting this info and then we can determine the next steps.
Thanks
Mar 22, 2022 at 4:39 PM
