How to remove drivers door panel?
2002 OLDSMOBILE SILHOUETTE
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
how to remove door panel to put window back on track?
May 3, 2010 at 8:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
remove the front door water deflector and inner belt sealing strip. to do this, start with opening the door and popping off the door trim plate. then remove the armrest screws. use special service tool (J38778 door trim pad remover) to remove the rest of front door trim panel. use a small flat blade tool to press in on the retaining tabs to release the front door window from the front door window regulator track.
May 3, 2010 at 5:11 PM
