Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Oldsmobile
Silhouette
Exterior Light
Headlight
Not Working
2001 Oldsmobile Silhouette Head Lights
2001 OLDSMOBILE SILHOUETTE
91,300 MILES • 6 CYL • FWD • AUTOMATIC
JJOHANSON
MEMBER
1 POST
FOLLOW
Both Head lights not working but high beams (same bulb) are working. I replaced both bulbs but still have same problem. Thanks for your help.
Jul 11, 2010 at 3:00 PM
KHLOW2008
CERTIFIED EXPERT
Hi jjohanson,
Thank you for the donation.
At the headlight switch, check that you have power coming out of the Yellow wire when the head lamp switch is turned on.
If power is present, test for power at the Tan wire at dimmer switch.
Jul 13, 2010 at 11:26 AM
