2000 Oldsmobile Silhouette water in oil
2000 OLDSMOBILE SILHOUETTE
DALDER1
2000 Oldsmobile Silhouette Two Wheel Drive Automatic 140000 miles
Have ater leaking into iol, No vapors from exhaust. would this be intake problem or exhuast problem. If intake can you supply directions on replacing gasket?
Nov 15, 2009 at 7:45 AM
MERLIN2021
  • 17,250 POSTS
Engine size? 3.4? Check for oil in antifreeze as well, it will turn milky white/brown in color depending on how clean the oil was. Compression test and cooling system pressure test will reveal eithe blown head gasket, or intake maniflold gasket. Ant foam, or bubles in the radiator?
Nov 15, 2009 at 8:51 AM
