2000 Oldsmobile Silhouette Harmonic Balancer out of alignme
2000 OLDSMOBILE SILHOUETTE
155,000 MILES • 6 CYL • FWD • AUTOMATIC
JCJEPICKETT
My van has broken 2 belts today, After the second belt, I started looking for why. It looks like the crankshaft pully / harmonic balancer is pulled out away from the block. I dont know what is wrong. Aside from the belt breaking, the engine runs great. I have checked the tentioner and it is operational. all other pulleys are working as designed. Cay you tell me why my crankshaft pulley is about 1/2 inch out of allignment, and How do I fix it?
May 9, 2009 at 2:16 PM
KHLOW2008
  • 41,814 POSTS
Hi jcjepickett,
Thank you for the donation.
When the harmonic balancer damper rubber has gone bad, the pulley would be out of alignment and moves in a wavy pattern.
Check if the crank pulley main bolt is securely torqued, if yes, the crankpulley has to be replaced to rectify the problem.
May 9, 2009 at 7:00 PM
