1999 Oldsmobile Silhouette cold engine warm up
1999 OLDSMOBILE SILHOUETTE
140,000 MILES • 6 CYL • FWD • AUTOMATIC
ALLEYBIG35
ok i am having a problem with van it only does it first thing in the morning when i crank it,(CRANK IT)if i do not let it warm up and hit the gas it will spit sputter actting like its not getting gas but does not stall fuel pumps been changed,fuel filter,wiring harness to fuel pump map sensor mass air flow sensor has been cleaned what could be causing my van to do this first thing in the morning after it warms up no problems till next morning drives like it never had a problem till next morning then same thing warm ti up and the vans fine help
Sep 27, 2010 at 11:07 AM
Has the check engine light come on? Have you checked fuel pump pressure?
Nov 4, 2010 at 1:45 PM
