1997 Oldsmobile Regency Car wont start
1997 OLDSMOBILE NINETY-EIGHT REGENCY
HELPER101
Engine Performance problem
1997 Oldsmobile Regency 6 cyl Automatic
Car wont start. Motor is not locked up, and car is getting fuel.
Sep 9, 2010 at 1:45 PM
If its cranking over and will not start-do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 9, 2010 at 1:48 PM
