no pulse in conectors, I have replaced ign module, coil , pick up coil, checked computer, fuses, sensors,wiring con., car doesn't even try to start. Started like a spark plug wire or coil missfire. Is a 3.8 VIN 3 PFI. Fuel pump press is 40 psi. Before it ran like a nice engine really smooth. Scanner says all is OK. What is the problem with the injectors? I get 12volts at the inj.s conectors. Dist checks OK
Nov 21, 2009 at 1:52 PM
