Stuck In Park
OLDSMOBILE
DRMEH
I just bought a 1997 Oldsmobile Cutlass with a 6 cylinder engine. Has only 49,000 miles. It's gear shift is on the console. When I crank it up and try to shift out of park, I cannot get it to move. I depress the brake as the book calls for and try to push in the button on the left of the gear knob, but it is just stuck. I even try to move the steering wheel from side to side with the engine turned on, but to no avail. I try and wiggle the gear shift while trying to push in the button, and only after about 3-4 minutes, it finally engages. Can anyone give me any insight on what to do so I can get on with driving? Is there a way to get into the knob where the button is attached to see if something is wrong? Can you spray some WD-40 into the side of the button to loosen things up? Thanks!
Feb 17, 2007 at 9:24 PM
CHEVY22
  • 1,375 POSTS
there are only two components it could be , the shifter itself or the brake transaxle shift interlock solenoid which is under the console itself , the btsi if i remember right comes with the cable now, you can pull the console and check for power and ground to the solenoid,
jim
Feb 18, 2007 at 5:12 PM
