Rear Brake Lights,Rear End, and Rear Brakes
OLDSMOBILE
ROHARRIS33
I have a 1995 cutlass supreme 3.1L mileage:107000. I am having a problem with my rear brake lights. The one at the top works fine, but the two at the bottom works intermittently for a while and now don't work at all. I checked some wires in the trunk and the connections looked fine. I also noticed when I push my turning signal about 3/4 of the way up both brake lights work. I check all of my bulbs and verified that they are working properly. Both turning signals work and the night lights work. Also when I'm driving above 25mph I begin to hear a whining noise and gets louder as I drive faster. And I have noticed that my rear brakes wear faster than my front and the outside pad on both rear calipers wear about twice as fast as the inside pads. I was thinking that my rear end is bent in some form.
Any advice that you have would be greatly appreciated.
Thanks in advance.
Aug 21, 2007 at 11:36 AM
CLY
  • 308 POSTS
As for the brake lights I would lean towards a turnsignal switch. the highmount light curcuit runs straight from the brake light switch as the curcuits for the lower brake lights run through the turnsgnal switch....
I dont have an awnser for your noise...Noises are a hard thing to advise on...
As for the brake wear problem. I would suggest that you make sure the caliper slides are lubed and moving freely. If they are then maybe it's time to replace those soft brake hoses.
Cly
Aug 21, 2007 at 5:26 PM
