Power Window Control Panel
OLDSMOBILE
MDOUGH
How do i fix the control panel for my power windows? I need an illustration. The car is a 1992 Oldsmobile Cutlass Cierra. It has a 3.3 liter engine and about 140,000 miles on it. The wires all came loose so i cannot roll my power windows up and down and i have no idea how to get the panel apart so i can reattach the wires.
Jul 28, 2007 at 10:07 PM
TDDBAD
  • 23 POSTS
Remove screws around door handle casing inside. Grab bottom panel of door and pull and cover will come off because it's plastic tabs that hold cover on. Then carefully hold bottom of panel and push straight up with a quick snap. Because there are clips at the top of the panel. Be carefull not to break clips. I have had to repail on my 92 several times. This must be a problem with these cars. Hope this helps.
Jul 29, 2007 at 11:24 AM
PASTORGKB
I have a 1992 olds cutlass ciera 162000 miles, electric windows quite working i checked the circut breaker there is power at fuse block and circut breaker checks out ok. no power at any windows. need advice.
Aug 2, 2007 at 6:12 PM
