I HAVE A 74 OLDS CUTLASS 350, WITH A HOLLY 600 4 BBL CARB. THE ENGINE HAS BEEN BORED TO 30 OVER, CRANK TO TO 10 UNDER AND HEADS SHAVED 10 UNDER. THE PROBLEM IS IT CRANKS AND WANTS TO START BUT DON'T. IT STARTS WHEN I TURN THR IGNITION KEY TO START POSITION AND HOLD IT THERE. WHEN I RELEASE THE KEY, IT CUTS OUT. I HAVE CHECKED EVEYTHING I CAN THINK OF. I HAVE SPARK AND FUEL TO THE CARB. I JUST REPLACED THE IGNITION SWITCH AND STILL THE SAME PROBLEM. THE IGNITION LOCK SEEM TO BE OK, THERE IS NOT MUCH PLAY IN THE LOCK. DON'T KNOW WHAT ELES TO TRY.
Jul 21, 2007 at 1:15 PM
