I have a 1993 Olds Delta 88 with about 140,000 miles on it. The engine is a V6 3.8L. I am having issues right now with "chugging" between 40 and 60 miles an hour. I have no problem getting up to speed but when I slow down and go to speed back up it stutters and then it will take off. The throttle body has been cleaned, new plugs, new wires, new fuel filter. There have been no check engine light and no codes were found on running a check. I visited a mechanic who indicated it may be an ignition coil or the transmission is malfunctioning in overdrive. Does this sound accurate? What might the problem be?
Thank you
Thank you
Feb 7, 2007 at 11:40 AM
