oil pressure switch leak
OLDSMOBILE
CUSTOMCRUZER
I have a pretty major leak from the oil pressure switch. I'm sure the threads are stripped. Can I have someone tap this hole or can I fill it with AlumAlloy or something similar?
Oct 26, 2006 at 5:05 PM
LSUSSEL
  • 252 POSTS
I suggest you replace it. Dont seal it off as if it needs to be replaced down the road it willl cause issues.
Nov 1, 2006 at 10:54 PM
CUSTOMCRUZER
It was suggested I replace my oil pressure switch. I cannot do so with stripped threads. Can this be tapped out (rethreaded) without doing damage to engine (metal shavings, etc.)....????
Nov 3, 2006 at 5:48 PM
LSUSSEL
  • 252 POSTS
Well depends.. does your car have an actual Oil pressure guage.. or does it just tell you when you have low oil pressure? I think yes you can replace it.. doing what you suggested as.. I belive the oil pressure sending unit swtich is located on the bottom or side of your oil pan.. I have replaced these many times on many cars. Are you familer with changing your own oil or where your oil pan is located?
Nov 3, 2006 at 11:11 PM
CUSTOMCRUZER
Yes--I have the "dummy" lights telling me when oil pressure is low...The area I'm talking about is on TOP of the engine as soon as you open the hood, you are looking right at it. The upper radiator hose runs about 4 inches over it. It's on the intake manifold or the block--i can't remember which--- pointing straight up........The oil pressure switch on my1982 Olds 307 is about the size/shape of a spark plug. I have already tried replacing it with a new one...It did NOT work so I took it back to Autozone.......problem is the RECEIVING threads inside the engine are stripped....Yes I have been under my car many a time for many oil changes, etc. This is the only problem keeping my beloved full size wagon off the road!......Ever heard of anyone using Alumalloy with a blowtorch to seal this hole off? I'm starting to think this is my only option....Thanks!
Nov 4, 2006 at 7:14 PM
