:? Howdy, I am having one heck of a time finding the map sensor on the wifes 1991 Olds 88 royale brougham with a 3800 engine. I wish to have it checked to see if it's bad and causing the high idle problem. I have checked extensively for vacuum leaks and have found none. replaced the mass air flow sensor and the one down there by the throttle position sensor that I can never seem to remember the name of. I have not yet replaced the throttle position sensor. I have plugged everything in hopes of finding a vacuum leak but to no avail. The car also likes to cut out when you reach a certain change in altitude as well. Any help would be appreciated, especially if someone could tell me where to find the map sensor, I traced every vacuum line and can't find it. Unless they have it mounted behind the electrical panel or on the cruise control I dunno where it is.
Thanks.
rfreezy, aka Krash
Thanks.
rfreezy, aka Krash
Dec 12, 2006 at 3:22 PM
