leaking valve covers
OLDSMOBILE
AARON KAYE
I have a 1971 Cutlass with a 350 rocket engine with 105,000 miles. I tried to change the gaskets on the valve covers and they continue to leak. If I tighten the bolts they break. Should I continue to try the cork or rubber gaskets as both leak. Is silcon better.
Thanks
Jul 19, 2007 at 10:49 PM
1934FORD
  • 6 POSTS
[quote:65da0d2ffb="Aaron Kaye"]I have a 1971 Cutlass with a 350 rocket engine with 105,000 miles. I tried to change the gaskets on the valve covers and they continue to leak. If I tighten the bolts they break. Should I continue to try the cork or rubber gaskets as both leak. Is silcon better.
Thanks[/quote:65da0d2ffb]
Silcone works the best for me just make sure they are clean before you use the silicone.
Jul 20, 2007 at 10:03 AM
