intake manifold
OLDSMOBILE
KCLO322
1996 Oldsmobile Cutlass Supreme SL, 140,100 miles
Hi. I was checkin the antifreeze level in my car and i noticed a thick brownish buildup around the top of the radiator. I was wondering if that was due to a leaking intake manifold or oil getting into the antifreeze somewhere else.
Dec 11, 2006 at 3:26 PM
GARFIELD
  • 197 POSTS
What size engine does the car have in it. It could be the intake manifold gaskets or possibly the head gaskets. Has the car overheated lately? You can do a compression test on the engine to see if you have two adjacent cylinders that are low on compression the head gasket is most likely blown. If your compression test is good then most likely either the intake gaskets are bad and need replacing, if it had the plastic composite upper intake, they are subceptible to cracking causing coolant to get into the oil. Hope this helps.
Gary
Jan 1, 2007 at 9:11 PM
SERVICE WRITER
  • 9,123 POSTS
May just be normal dex-cool sludge build up around the neck. Is it milky colored?
Jan 1, 2007 at 9:47 PM
