inoperative fuel pump
OLDSMOBILE
DOBSY
I have a 1994 cutlass ciera with about 200k miles on it. The motor will crank but not start. The fuel pump is supposed to come on with the key. I had an assistant turn on the ignition while I placed my ear to the fuel tank to listen for the fuel pump to activate as was reccomended by my repair manual - nothing. Fuel pump operation can be inhibited by the ECM or a blown fuel pump fuse which I can't find. The repair manual says it's mounted on the firewall - not so. I noticed just prior to this failure that the fuel gauge would intermittantly peg at "full", returning to normal for brief periods. Since the fuel pump and the tank decender for the fuel guage are both mounted in the fuel tank I suspected a short that perhaps blew the fuel pump fuse but can't find a frayed wire along the harness leading to the tank or the fuse. Any advice?
Jul 21, 2007 at 8:17 PM
KIN CHAN
  • 453 POSTS
yes
Jul 21, 2007 at 8:51 PM
DOBSY
[quote:514e5fa1ad="kin chan"]yes[/quote:514e5fa1ad]
It's an Oldsmobile (sorry), Cutlass Ciera, 1994, 200,000 miles, 3.1l auto trans.
Jul 22, 2007 at 8:56 AM
KIN CHAN
  • 453 POSTS
chk wiring diagram for pwr & grd to the fuel pump....key on/engine off fuel pump has good pwr & grds --> most likely fuel pump ---> good luck
Jul 22, 2007 at 11:21 AM
ROCKWOOD84
  • 103 POSTS
if the gauge is erratic then could be a ground wire loose but usually on an olds when the fuel gauge starts to go crazy the fuelpump will go out a short time later. if you can hear the fuelpump running put a fuel pressure gauge in the fuel line usually put them in where the fuel filetr is and see if you have 40lbs fuel pressure. the fuel pumps that g.m. uses are made in mexico and are cheap made almost all plastic. the pump may be running and not pumping.
Jul 22, 2007 at 2:31 PM
