Idle Is High
OLDSMOBILE
DELESTER1980
Hi I have a 1994 Oldsmobile Cutlass Supreme with a 3100 V6 from a 1998 Chevrolet Lumina. This car is Idling @ 1500-2000 rpm. I have Changed the Egr valve, Iac, Tps, and even adjusted the Idle. Is there any other sensors that I can change or check to make this problem go away.
May 5, 2006 at 8:03 PM
LOSONE
  • 1,616 POSTS
Just how did you adjust the idle?? You may have a bad idle air controller or a dirty MAF sensor.
May 6, 2006 at 10:04 AM
