Help!! I have a lot of white smoke coming from my exhaust!
OLDSMOBILE
SYBERTYGER
  • 4 POSTS
I have a 94 oldsmobile cutlass supreme with 180000+ mileage. The engine is a v6 3.1liter. I have a lot of white smoke coming from my exhaust when I give it some gas. The engine knocks a little and it sounds different when I start the car. When I first noticed the problem I saw what appeared to be steam coming from the back of my engine under the hood. What could possibly be wrong. I suspected it to be a blown head gasket, but my cylinder block may also be cracked. What do you think is the problem? Please help me.
Jul 17, 2006 at 1:34 AM
XOWEY
  • 113 POSTS
this sounds serious...................is the coolant low?
Jul 19, 2006 at 8:21 AM
SYBERTYGER
  • 4 POSTS
The coolant isn't low and there doesnt appear to be any oil mixed with it or water in the oil. What do you think it could be
Jul 19, 2006 at 8:42 AM
XOWEY
  • 113 POSTS
it could be an injector leaking or sticking open
Jul 19, 2006 at 10:24 AM
SYBERTYGER
  • 4 POSTS
Hopefully I havent' damaged anything too bad and it can be easily and quickly fixed, but if that isn't the case what else could it be
Jul 19, 2006 at 10:32 AM
XOWEY
  • 113 POSTS
if it knocks a little, you could also have a piston problem.
a compression test could show somwthing.
Jul 19, 2006 at 10:35 AM
SYBERTYGER
  • 4 POSTS
The exhaust smells like the engine is burning rich and the oil kinda smells like gas
Jul 20, 2006 at 9:29 PM
