Fuel Filter 1988 Olds Cutlass Supreme Classic 5.0 4bbl
1988 OLDSMOBILE
NATE
I have a 1988 Oldsmobile Cutlass Supreme Classic with a 5.0 Liter engine and a 4 barrel Carb. I was wondering where the fuel filter is located on my car.
Jun 16, 2006 at 1:32 PM
RCR293107
assuming this is a 307 olds motor,the fuel filter is inside the fitting that attaches to the carb fuel line,you must disconnect the fuel line first.this screws into the carb.it has the filter and a spring inside of it,it also has a nylon seal at the end of the fitting when you unscrew it off the carb.hope this helps.
Sep 14, 2006 at 5:56 PM
