Check Engine Codes
OLDSMOBILE
WKIML
  • 6 POSTS
I own a 1997 Oldsmobile 88 V6 with anut 140k miles on it
My check engine light is on I took it to a "car center" and they gave me the following codes
P0125 Insufficent time or temp for closed Loop
P01655 Purge, EGR or shift solenoid a circuit
When I tried to check these back against the OBD database it doesn't even recognize a P01655 error
Anyone have any idea what these mean in layman's terms
Apr 24, 2007 at 5:07 PM
WKIML
  • 6 POSTS
[quote:f164dd9f12="wkiml"]I own a 1997 Oldsmobile 88 V6 with anut 140k miles on it
Anyone have any idea what these mean in layman's terms[/quote:f164dd9f12]
Let me add than when I first start up the car it runs fine until the temp reaches 200 at this point the car shakes/sputters at stop signs and red lights , has next to no acceleration and backfires often between 15-30 mph
Also I am all thumbs so any repairs would need to be done by a professional I've dumped over $2000 into the car the last 15 months and not looking to significantly add to that total
Apr 24, 2007 at 5:54 PM
WKIML
  • 6 POSTS
so much for making a donation to get your question answered quicker
Apr 26, 2007 at 8:39 PM
sorry about the wait, frist thing we need to do is check the thermostat, if it is stuck open it will set the first code. Next it sounds like the egr control seliniod could be shorted, removethe electrical connector and check the ohms resistance between the two termnails and see what it is, please get back to me.
Apr 28, 2007 at 11:44 AM
WKIML
  • 6 POSTS
[quote:55786c6a86="2CarPro Ken"]sorry about the wait, frist thing we need to do is check the thermostat, if it is stuck open it will set the first code. Next it sounds like the egr control seliniod could be shorted, removethe electrical connector and check the ohms resistance between the two termnails and see what it is, please get back to me.[/quote:55786c6a86]
took it to a mechanic today as I was in fear of doing permanant damage to the engine
The compression tests came back fine But i have a leak in the fuel line and the coils and spark plugs all need to be changed ($800 for parts and labor ugh...)
Having no knowledge about cars I have another question. The previous shop used Bosch spark plugs, the mechanic today says these types of plugs really should not be used in domestic cars, they are better served in BMW/Audi type vehicles. Is his statement correct?
Apr 28, 2007 at 6:27 PM
