I have a 96 Oldsmobile Cutlass Supreme with a 3.1L with a 146000 miles on it. The check engine light came on and it start run rough so I took it Autozone and had them put the scanner on it. It said it was either the coil or the injector on the #1 cylinder. I checked the coil it was good and I got spark so I replaced the injector but still same problem, so I ohm'd the new injector the old injector and the #2 injector the all ohm at 12.3. So I swaped the #2 with the #1 still same problem. I ran the motor with the #1 spark plug removed and all that came out was alittle bit a mosture but no fuel. Now I am getting a lot of white smoke and alot of mosture out of the exhaust (head gasket?) and my coolant looks like crap but it is 100000miles old. I find it hard to believe that I lost (have) a injector problem and loose a head gasket all at the same time. Any help would be welcomed. Thanks
Sep 22, 2007 at 4:26 PM
