Cam Sensor
OLDSMOBILE
MADCROW
Hello, I have an 88 Oldsmobile Cutlass Siera 79,000mils, Harmonic Balancer was grinding so i replaced it while doing so i broke the crank Sen forgot to replace it before attempting to start the car :( " *^': " think this was a bad thing...replaced it and now the car will just turn over but not start. Im getting spark and presure through the valve on the fuel rail but still wont start, splashed some gas in the cylinder and it attempted to start but then quit. Cam Sensor maybe? Thank you in advance.
Aug 3, 2006 at 12:43 PM
DAYNITETOW
Have you measure resistance on the coil pack? I was told if it read over 200k Ohms that it is bad. I had where the belt broke and damaged the Crankshaft sensor so I had that replaced only to find that a short had occur in either the Ignition module or coil pack so had both replace and it worked and now another simtum had appear.
Sep 8, 2006 at 8:22 PM
