REMOVE OR DISCONNECT
Air cleaner assembly.
Negative battery cable at battery.
Coolant recovery tank and position aside.
Serpentine drive belt.
Raise vehicle and suitably support.
Both tire and wheel assemblies.
Right engine splash shield upper retaining clips and pull down shield.
Front exhaust pipe and converter assembly.
Generator splash shield retaining screws and shield.
Right ball joint nut and separate control arm.
Right drive axle from transaxle.
Steering gear heat shield retaining screws and shield.
Knock sensor electrical connector.
Generator cooling duct. Refer to "Generator Cooling Duct".
Generator rear brace bolt.
Access bolt through left wheel opening using a 4 foot extension.
Loosen generator rear brace nut at engine.
Access nut through right wheel well behind generator.
Power steering clip and upper generator stud nut.
Generator electrical connector from generator.
Battery positive lead and nut from generator output ("BAT") terminal.
Generator assembly upper stud, lower bolt/screw and washer.
Generator assembly.
INSTALL OR CONNECT
Generator assembly.
Generator electrical connectors to generator.
Battery positive lead and nut to generator output ("BAT") terminal. Tighten Nut to 20 Nm (15 ft lb).
Generator to mounting bracket and loosely install washer, lower bolt and upper stud.
If replacement generator does NOT fit, remove adhesive-backed shim from generator bracket (see Figure).
Generator rear brace and bolt, including cooling duct bracket.
Parts should fit easily. Tightening bolts and nuts MUST NOT put generator assembly in a bind.
Tighten
Generator lower mounting bolt to 50 Nm (37 ft lb).
Generator upper mounting stud to 25 Nm (18 ft lb).
Generator rear brace nut to 50 Nm (37 ft lb) by accessing through right wheel well behind generator.
Generator rear brace bolt to 25 Nm (18 ft lb).
Upper generator stud nut and power steering clip.
Generator cooling duct. Refer to "Generator Assembly Cooling Duct".
Steering gear heat shield and retaining screws.
Right drive axle to transaxle.
Right control arm and ball joint nut.
Steel drive axle shield and retaining screws.
Right engine splash shield using upper retaining clips.
Lower vehicle.
Serpentine belt.
Coolant recovery tank.
Negative battery cable at battery. Tighten Cable bolt to 15 Nm (11 ft lb).
Adjust transaxle fluid level as necessary.
Aug 22, 2006 at 6:02 PM
