all new parts and no fire...
OLDSMOBILE
RANDYEPPERS1980
i have a 1983 Oldsmobile Delta 88. mileage is 136,000. Engine is a 307 cubic inch V8 with a 4 barrel carb. The motor turns over but i have no spark. I pulled the spark plug wire on the no. 1 cylinder and there is no spark. I have replaced the following: New distributor cap, rotor button, plugs (gapped to .080), plug wires, coil, pick-up coil and ignition module. My Haynes book states that the distributor in my vehicle is "maintenence free". I assume that means that all the distributor does is turn the fly wheel. When i replaced the pick-up coil, I inspected the teeth on the bottom of the distributor for damage. Nothing. Please help me. I'm about to crack up!!
Sep 8, 2007 at 11:45 AM
[quote:a275a3ab65="randyeppers1980"]i have a 1983 Oldsmobile Delta 88. mileage is 136,000. Engine is a 307 cubic inch V8 with a 4 barrel carb. The motor turns over but i have no spark. I pulled the spark plug wire on the no. 1 cylinder and there is no spark. I have replaced the following: New distributor cap, rotor button, plugs (gapped to .080), plug wires, coil, pick-up coil and ignition module. My Haynes book states that the distributor in my vehicle is "maintenence free". I assume that means that all the distributor does is turn the fly wheel. When i replaced the pick-up coil, I inspected the teeth on the bottom of the distributor for damage. Nothing. Please help me. I'm about to crack up!![/quote:a275a3ab65]
Check for power to the coil positive while cranking it over-if its less than 7 volts check your wiring back to ignition switch.
BTW ignition coils with red and white leads should be match with pick-up coil having a clear,a black or blue connector. Ignition coil with red and yellow leads must be matched with pick-up coils with a yellow connector
Sep 8, 2007 at 3:41 PM
