2002 Other Oldsmobile Models heater blowing cold and overhea
2002 OLDSMOBILE
92,000 MILES • V8 • FWD • AUTOMATIC
SRQ1022
I have a 02 Olsmobile Silohette and recently the heater started blowing only luke warm to cold air and my temp gauge is going all over the place and overheats if the car isn't moving. The heater blows luke warm when the temp gauge shows ablut 1/4 and then blows cold when it gets up to 1/2. We replaced the thermastat and it is still having the problem. Can you help please.
Jan 25, 2008 at 1:06 AM
Did you check the heater core could be partially clogged-also bleeding the cooling system. Might also be a heater control valve/air mix and blend/mode door/actuators and vacuum/hose problem.
Water pump failing or Fan clutch or fan not functioning right
Jan 25, 2008 at 1:14 AM
