How to reset windshield wiper timing?
2001 OLDSMOBILE
85,000 MILES • 6 CYL • FWD • AUTOMATIC
M.BEIER
the arm that is connected to the motor came unbolted. i reconnected it but now the wiper timing is not right. how do you set the timing?
Dec 17, 2008 at 9:03 AM
SQM
  • 6,383 POSTS
In order to put them both in the correct sequence. First remove the arm that came off before. Shut the switch to the off position. The install the arm parallel to the second wiper arm. This will keep them in sequence.
Also keep in mind that if the spline on the arm or the shaft is worn the wiper will go out of sync again. So inspect and make sure the component in good condition. If not replacement of the arm or the shaft would be necessary.
Here is a helpful video:
https://youtu.be/4YhpeoZoKu8
Thank you.
Nov 11, 2021 at 10:29 AM
