2001 Olds Alero quad 4
2001 OLDSMOBILE
MALONE628
During the past 9 months after having a computer hooked up to my vehicle, it has been determined that cylinder 4 is misfiring and the mechanics seem to thing that it is an injector problem. I have run injector cleaner through it 3 times and it has curbed the problem somewhat, but the check engine light and trac off light go on and off on a regular basis. The car is misfiring but it will go some days w/o doing so. If it is an injector which seems to be the most likely scenario, would that be something that I could change myself and how much would it cost for an injector for that vehicle based on your knowledge? Thank you folks...John
Jul 4, 2007 at 4:49 PM
ROCKWOOD84
  • 103 POSTS
get you a repair manual chilton or haynes get one for 2001 olds alero and you can pull the injectors and trouble shoot it will walk you through it.does it have 3.4 in it?
Jul 22, 2007 at 4:16 PM
