1998 Oldsmobile HOW TO REMOVE SHIFTER HANDLE
1998 OLDSMOBILE
125,000 MILES • V8 • 2WD • AUTOMATIC
MIKE1125
How do you remove the shifter handle on a 1998 Olds Aurora?
Please help, I'm going nuts.
Thanks,
Mike
Dec 3, 2007 at 2:42 PM
TECH1
  • 4 POSTS
On the front side of the handle (toward dash) ther should be a small clip to pry out, then pop up the shifter boot from the bottom, lift the handle up carefully because ther are some wires there that will pull/break. Those must be disconnected when lifting the boot up and before the handle comes all the way off.
greatautohelp.com
Dec 3, 2007 at 9:36 PM
