1997 Olds Bravada won't stop
1997 OLDSMOBILE
LJAGOW
When I stop the car, put in park, I can remove the key and the engine continues to run. When I shift to Reverse the engine stops and I put on the parking brake. If I put the trans in Park the dash light up and the fuel pump cycles. I changed the ignition switch thinking that it might be bad, tried a few times and the engine went off with car in Park and key was removed. After 10 minutes same problem existed. Car will not turn off with key out in Park. Is there a sensor bad in the shift or console? Please help
Oct 3, 2007 at 3:05 PM
If its doing that the main power input to the ignition switch is shorting out to the igniton circuit.
Oct 3, 2007 at 3:27 PM
LJAGOW
Is there something I need to look for and where? Is it in the wiring block or a bad switch?
Lee
Oct 15, 2007 at 3:10 PM
For a start check the wiring going to the ignition switch. Check whether the power input to the switch is touching the ignition feed.
Oct 15, 2007 at 5:28 PM
