1995 Other Oldsmobile Models Help request
1995 OLDSMOBILE
18,000 MILES • 4 CYL • 2WD • AUTOMATIC
EDUARD70
I had a nightmare called Olds Achieva. I have an electrical issue with turn right signal which is not flashing(although is comming on). The turn left signal and warning lights are OK. I checked the right bulbs and all are OK.It could be the flasher , but where it is hide.
Any help is welcome.
Dec 13, 2007 at 7:42 PM
JOSHWILCOX26
the flasher fuse is located under dash drivers side. You have to unscrew the panel below the dash and let it hang. there is a second panel u need to unsrew its under that near the steering column. there usually white and plastic. I hope this helps.
Mar 28, 2009 at 10:24 AM
