Engine problem
1994 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 70k miles
I had a miss and a vibration found the miss to be #2 cylinder did compression test oh god "0" that is ZERO and there are no noises and no oil on plug when you run it plug out no oil there is a little carbon on the plug..not sure what could be>>>new engine?? new heads ??will remove value cover and look at lifters >>can a valve be open and not hit the piston???
thanks Bill MClary
thanks Bill MClary
Dec 25, 2007 at 7:30 PM
