hello - 1st time here - i have a 1992 olds cierra that has had the entire cooling system replaced - new radiator, themostat, head gaskets, pressure tested the system - the temp gauge shows the car is running a little over the 1/2 way mark & somtimes it shows running hot - this happens sporatically - seems like when the car warms up & is running for a while it goes away - or it jumps up in temp & then quickly goes back down - i have almost $2k invested in this problem - i have checked the fan to make sure it is running & not slipping for the radiator & it is good - this is my only car & i am half afraid to drive it like this - any help would be greatly appreciated - thank you - it is the 6cyl - milage is 80-100k
Feb 21, 2007 at 6:18 AM
