when i turn key overi hear no fuel pump and car wont start,, is there a fuse or relay or is pump bad
Jan 25, 2008 at 9:40 AM
M.SEXTON
MEMBER
A QUICK CHECK TO SEE IF YOUR PUMP IS WORKING,LOOK BY YOUR BATTERY,YOU SHOULD FIND A GREEN PLUG THAT GOES NOWHERE. THIS IS A HOT WIRE TO THE PUMP,RUN A JUMPER WIRE FROM THE HOT SIDE OF YOUR BATTERY TO THIS WIRE, THE PUMP SHOULD RUN,IF IT DOES, CHECK YOUR FUSES OR RELAY UNDER THE DASH, IF NOT THE PUMP IS BAD.
