1988 Other Oldsmobile Models exterior lights
1988 OLDSMOBILE
230,000 MILES • 6 CYL • FWD • AUTOMATIC
RAYBO100
  • 6 POSTS
My 1988 delta 88 royasl brougham has opera lights on the door posts I can trace the wire into a large harness going towards the front of the car and lose it inthe harness, as the opra lights are not lighting up I am assuming it is a burnt out bulb and this is the fiber optic cable (same as the light around the keyhole ) Question -where is the bulb located manual does not even id the opera lights, I have looked many places but cannot find it (both sides of cars lights are out)
Feb 23, 2008 at 5:21 AM
2CARPRO JACK
  • 11,533 POSTS
Go here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
full wiring diagram and locator for all fuses an accesories
Feb 23, 2008 at 7:48 AM
RAYBO100
  • 6 POSTS
I have electrical diagrams from chiltons it has every wire in it but the wires for the opera lights and key holes
Any wiring diagram I have seen is a schematic and it does not say where it is physically located in the car so I would think this is problably the same
Mar 1, 2008 at 2:21 PM
2CARPRO JACK
  • 11,533 POSTS
It uses a solid state inverter (electro-luminescent) my diagram has it, but I cant finda location anywhere in the locator.Closest I have seen is the inverter for the instrument cluster, It may be the same.It is under the right side of the dash above the glove box.
Mar 2, 2008 at 7:23 AM
