1983 Other Oldsmobile Models battery
1983 OLDSMOBILE
50,000 MILES • V8 • AWD • AUTOMATIC
THUMBERT
what kills a brand new battery
Apr 4, 2008 at 8:24 AM
A short circuit within the electrical system or your alternator not putting out -do below
Get a test light and disconnect the negative battery cable now put the light between the cable and battery negative post is the light On? If so start removing fuses one at a time -the fuse that turns off the light is the trouble circuit. Then break out the electrical wiring diagram.
In the event you removed all the fuses and the light is still On disconnect the alternator batt. feed and the connector-if this one turns off the light-the alternator has bad diodes.
Apr 4, 2008 at 8:27 AM
