2002 Oldsmobile Intrigue egnition
2002 OLDSMOBILE INTRIGUE
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSEPHR
  • 18 POSTS
my brother oldmobile intrigue , started having problems with starting . he went shopping then he came back wouldnt start , he called GM they told him to wait 15 min the try and it starts . It happened twice so far
I read about something security light , what seem to be the problem ? when the security light was solid then it started . Is there a sensor that need to be replaced ?
I hear common problem in all intrigues . GM seem to be aware of the problem . let me know what is the problem ? you probably aware of it too. thanks
Aug 24, 2010 at 3:38 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Is theft deterent PASSLOCK? ie. does key have a little black chip?
Let me know
Thanks for donate
Aug 24, 2010 at 3:53 PM
JOSEPHR
  • 18 POSTS
Hi
No it doesn't have a key chip you can start it with any duplicate key . Let me know my brother is desperate to fix thanks
Aug 25, 2010 at 6:42 PM
DOCFIXIT
  • 18,828 POSTS
Try this relearn key on no start Theft light should light and flash for about ten min. then go solid turn key off repeat two more times. If Theft /security is on solid then a chip needs to be replaced on ignition. Prohibits injector function if car is started without key.
Aug 26, 2010 at 11:43 AM
