2000 Oldsmobile Intrigue kind of annoying
2000 OLDSMOBILE INTRIGUE
FLIPNASTY
Electrical problem
2000 Oldsmobile Intrigue Two Wheel Drive Automatic 156xxx miles
the car is pretty much all power inside,when i start the car most of the time the air and cruise control and the dimmer and compass in the rearview mirror,and the heated seats dont turn on.sometimes after driving for a little while they kick on then work normally,sometimes they dont turn on or sometimes they are working when the car starts then turn off.the engine and other instruments are not effected.is there any common fuse or relay that all those share?any ideas?the battery seems fine also
Feb 20, 2010 at 12:36 AM
A bad fuse wouldn't work at all. Therefore, you can check the relay block under the hood, but I know there isn't "one" they all share. If I had to guess, I would say have the ignition switch checked.
Apr 13, 2010 at 10:40 AM
