2000 Oldsmobile Intrigue
2000 OLDSMOBILE INTRIGUE
JOHNGEHRLS
The Heating and Air conditioning system blows hot air out the dash vents on the driver side all the time, even when the passenger side is blowing cold air as the controls are set. All fuses seem to be fine. Any ideas?
May 10, 2010 at 7:59 PM
Each side has a blend door. It determines if you get heat or AC. One is either stuck or damaged. Check them and let me know what you find.
May 19, 2010 at 7:54 AM
