1998 Oldsmobile Intrigue Unable to start car
1998 OLDSMOBILE INTRIGUE
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTANNANOW
  • 6 POSTS
I have a 98 Olds Intrigue. While driving home, I went to pass another car and as I accelerated, the car jerked and started losing power. Trac off light came on as well as service engine light. However, the car seemed to gain power but then it started to overheat. I pulled into a gas station and a mechanic there saw that there was no coolant in the radiator. We added water but the car didn't want to start. He read the DTC and said that it read multiple misfires. The car finally started and I nursed it home but it ran rough the whole way and died once. Found the coolant leak which was caused by a rotted intake plenum seal which was causing massive coolant loss and pooling of coolant on the top of the intake manifold. There was no water found in the oil or coolant found when spark plugs were cleaned. Replaced the plenum seal, replaced the thermostat housing seal. Checked and all cylinders have fire. The fuel pressure is approx 46 psi. But the car still won't start. Unfortunately didn't get the DTC's before removing battery cables so it cleared the computer of the codes (yeah, shoulda thought of that but didn't). I have fire and fuel. When I try to start the car, it sounds like it wants to catch and backfire but can't quite get there. There are no off mechanical sounds, like clanging or whining. So what could be some of the other problems? I've thought of the crank positon sensor, the ignition module but is there anything else? And if it is the crank position sensor, does anyone know how much it would cost to replace or if it can be tested to see if it needs replacing?
Aug 31, 2009 at 11:03 PM
JDL
  • 16,098 POSTS
Did you visually check for spark? Did you try starter fluid in the intake? Usually I take the air-duct loose from the throttle-body, open the throttle-valve a little and squirt some in there, see if the engine tries to start. There could be a safety issue using a flammable spray. The safety issue is your responsibility. I've never had any problems,but, I have heard of others having problems.
Sep 1, 2009 at 12:17 PM
JUSTANNANOW
  • 6 POSTS
I don't use starter fluid since burning all the hair off my arm over 20 years ago. And just curious, but wasn't I supposed to get an answer from "certified professionals"?
Sep 2, 2009 at 9:22 PM
JDL
  • 16,098 POSTS
Hello again, you might talk to [email protected]
Sep 3, 2009 at 8:31 AM
THIS IS MIKE
  • 686 POSTS
Hi Anna,
Our Moderators are Certified Technicians. We have refunded your donation, but would still like to help you.
Thanks,
Mike
Sep 4, 2009 at 1:50 PM
JUSTANNANOW
  • 6 POSTS
Thanks Mike, and jdl123 I do apologize. I didn't realize you were also a technician. So aside from using starter fluid, which I'm scared to do anymore, is there anything else that you can suggest?
Sep 5, 2009 at 1:24 PM
JDL
  • 16,098 POSTS
No problem, can you check for an injector pulse, with engine cranking? You can also try cranking with the cam sensor unplugged. Place the connector where is doesn't get caught-up or short to anything.
Sep 5, 2009 at 2:01 PM
JUSTANNANOW
  • 6 POSTS
How do you check for an injector pulse and what would I be looking for? And what should happen with the cam sensor unplugged? I'm used to distributor caps and carburetors. lol
Sep 5, 2009 at 4:09 PM
JDL
  • 16,098 POSTS
The autostore sells a noid lite, to check for injector pulse. A faulty cam signal may be worse than no signal at all. With the sensor unplugged, the injectors may revert to mfi instead of sfi, just a thought.
Sep 5, 2009 at 9:51 PM
JUSTANNANOW
  • 6 POSTS
Sorry, lost internet for a couple days. Can you tell me where the cam sensor is located on this car and how to unplug it?
Sep 9, 2009 at 12:26 AM
JDL
  • 16,098 POSTS
It should be on the passenger-side end of engine, above the crankshaft, three wire connector.
You need to figure out if any fuel is getting into the cylinder?
Sep 9, 2009 at 10:15 AM
JUSTANNANOW
  • 6 POSTS
Had to remove the fuel "rack" that the injectors are on, and there was gas in that rack and in the injectors. Assumed that fuel wasn't the problem.
Sep 9, 2009 at 11:57 AM
JDL
  • 16,098 POSTS
I'd use a gage and check fuel pressure. Also, check for injector pulse, engine cranking. Take the connector loose from the injector, use a noidlite on the electrical plug. The lite should flash with engine cranking.
Sep 9, 2009 at 12:09 PM
