1998 Oldsmobile Intrigue Think Transmission is gone:(
1998 OLDSMOBILE INTRIGUE
195,400 MILES • 6 CYL • FWD • AUTOMATIC
HEZEKIAHLEE
I drove all day and I stopped for 5 minues, the car was still in drive, when I went to press on the gas the car didnt move...I put the car in reverse and it moved as normal..I tried to put in gear 3 and still didnt move..put it in 2 it went some but made a weird noise..but when in gear 1 the car drove...also before doing the different gears I added transmission fluid.. mechanic say transmission is done or maybe water pump but he would have to take it out to check it...mechanic also metioned there was no water going thru the pump..very little air???? please help would like a second opinion would like to get fixed ASAP...
Apr 7, 2010 at 10:41 AM
I'm at a loss. The mechanic told you the trans problem may be the result of a bad water pump?
Apr 13, 2010 at 9:18 AM
