1992 Oldsmobile Intrigue strange noise, getting worse
1992 OLDSMOBILE INTRIGUE
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRACYLOVESDAVE
The left front wheel area is making a squealing noise while the wheels are rolling straight and higher pitched turning to the right, no noise at all turning left. Gradually getting worse. Can you tell me what this problem is?
Nov 29, 2008 at 8:52 PM
JAMES W.
  • 2,394 POSTS
Sounds like a wheel bearing. If it is worn to the point where it is making that much noise, you should be able to jack up one side at a time and physically shake the wheel with the bad bearing. Hope this helps.
Nov 29, 2008 at 9:03 PM
