1985 Oldsmobile Firenza Not running
1985 OLDSMOBILE FIRENZA
100,000 MILES • 4 CYL • FWD • AUTOMATIC
WESTBY
I have a 1985 Olds Firenza that a short time ago started cutting out. About a week later it quit running. Fuel is good. No spark to spark plugs. I took the coil and ignition control module to an auto parts store to be tested. Was told the coil was bad but when I replaced it it didn't help. Would relly appreciate any help. Thanks,
Jan 19, 2009 at 12:58 PM
MERLIN2021
  • 17,250 POSTS
If you have a tachometer, check the tach wire for grounding on metal, this will prevent the car from getting spark., what did the parts store say about the ignition module?
Jan 19, 2009 at 1:03 PM
