car will not start. checked battery replaced starter. believe problem may be the key cylinder or some type of switch. problem is not consistent. car may start fine ten times then not start at all. dosent matter if you stop car and restart or car sits for a long period of time. have tryed playing with the shift lever (on the colum) and the key. seems if car sits and i continue to try and start (5min) it will eventually turn over. any tests i can do or advice would be greatly appreciated. its a great car. thanks
Oct 29, 2009 at 12:15 PM
