Dads car, one day would idle then stop, installed new battery, plugs, wires, removed coils, bottom plate, cleaned lubed, new crank position sensors, new idle control sensor and one other sensor near the Idle control one, put Heat & seafoam in gas plus 5 gallons 93 octain. Tested fuel pump pressure and installed new filter. After all of that it did the same thing, run 4 minutes then stop dead. trying to restart it would cause it to run for less time before it died and if you tried to give it gas it would pop threw exhaust. Then yesterday out of the blue it stayed idling for a half an hour, I took it for a 5 mile drive and then it started sputtering at my drive and now it is back to the same thing, idle 4 minutes and then die, try and start it and it idles for less time and if you try to give it gas it pops threw exhaust. Don't want to take it to mechanic if I don't have to, money is an issue. Thanks in advance
Feb 7, 2009 at 11:00 AM
