1990 Oldsmobile Delta 88 Very firm pedal with very limited
1990 OLDSMOBILE DELTA 88
BB650
  • 7 POSTS
Brakes problem
1990 Oldsmobile Delta 88 6 cyl Front Wheel Drive Automatic
Hi to all, as I was driving home from work I noticed the Brake and Antiloc warning lights came on. I touched the brake and they worked as mormal however a few moments later I heard a warning chime, the lights remained on and the brakes still worked as normal. After highway driving for 15 min. and driving through small town trafic and intersections I was about a block from home when I wanted to slow for a stop sign, the brake pedal had become very firm and brake response almost nothing, I managed to park in my driveway safely. My first thought was that the problem was the brake booster, but this is a whole other system.
My car has the Teves 11 ABS system I have a code reader and found code 27 and code 47. Code 27 is the: Rear outlet valve, can someone tell me more about this and where to find it? My Haines manual shows nothing.
Mar 13, 2010 at 2:38 PM
Have you checked fpr a vcacuum leaks>
May 20, 2010 at 9:00 AM
